NI TestStand
Change text color in HTML report step headers and results
I would like to be able to change the color of the text that shows up in the step header and results boxes for certain steps. Currently black is the default color. I can modify the background colors using the report options but I can't find a way to modify the color of the text that shows up in those boxes. Is there a particular variable in the reportgen_HTML sequence in parameters.reportoptions.colors that I can change to modify the text color?
(3,140 Views)
Although report option provide some customized functions in report color, main text isn't include in that function. But it's HTML format. So maybe you can add the css text by text crawler later.
(3,055 Views)
