NI TestStand
Changing Station Options with a Sequence File
Is there a way to modify the "Debug options" located under "Preferences" tab in Station Options in TestStand by running a sequence file? I would like to disable the default "Report Object Leaks" option located under "Debug options"
Also, can I disable Report Generation located under "Report Options" by running a sequence file?
Response is appreciated. Thanks.
(3,285 Views)
Hey Troy12,
Yes, there does appear to be a way to set these programatically - you can do it using Active-X steps. You'll need to get a reference to the Station Options in the TestStand API 3.5, then as an action, Set Property, and then select Debug Options. From there you can set the input value to 0 to disable all debug options. The TestStand help file has more details if you search on "DebugOptions Constants".
Also, you can disable Report generatation using the Report Options Callback and setting the "Parameters.ReportOptions.DisableReportGeneration" to True.
Hope this helps.
-Jack
(3,274 Views)
Dont forget that the Report Options are set before the main process model loops.
If you wanted to disable the report once you are into the Client sequence file, you might beable to affect the Local copy of the ReportOptions by using RunState.Caller.RunState.Locals.ReportOptions
Regards
Ray Farmer
Regards
Ray Farmer
(3,270 Views)
