NI TestStand
Check for Sequence Running via Model
The attached immage shows how to determine the steptype name.
I've also attached a simple example that demonstrates how to filter step names.  Let me know if this makes sense.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
Message 11 of 14
(1,994 Views)
Hi Jigg,
Is there a way to find out whether or not a sequence or step is main of the Main Sequence and in the Main block?
Message 12 of 14
(1,982 Views)
Yes.  Inside the callback use RunState.Caller.StepGroup
0 = Setup
1 = Main
2 = Cleanup
Hope this hleps,
jigg
CTA, CLA
testeract.com
Message 13 of 14
(1,980 Views)
I should point out that it is probably safer to use the constants:
StepGroups
Use the following constants with this data type:
  • StepGroup_Cleanup–(Value: 2) Specifies the Cleanup step group.
  • StepGroup_Main–(Value: 1) Specifies the Main step group.
  • StepGroup_Setup–(Value: 0) Specifies the Setup step group.
Purpose
Returns the step group in which the step currently resides.
Remarks
If the step is not currently inserted in a sequence, accessing this property returns an error.
Also, of note is that instead of Caller.StepGroup  You could use RunState.Caller.Step.StepGroup
So do a compare like this RunState.Caller.StepGroup == StepGroup_Main
jigg
CTA, CLA
testeract.com
Message 14 of 14
(1,979 Views)
