NI TestStand
Check with REGEX, value from MessageBox
Hii,
I want to check the validity of the data entered in a Messagebox with Regex ??
Best
Akshay
(1,621 Views)
Hi Akshay,
if you are generally asking about how to use regular expressions in TestStand:
As far is I know, TestStand still does not support regex directly.
However you can use the Windows Regex Library for that by calling it in a .Net Action Step like this:
As for accessing the text entered by the user into the Message Popup, you can access it via Step.Result.Response.
Stefan
(1,608 Views)
Akshay/Stefan,
TestStand does support regular expressions directly in TestStand. It can be done in the following ways:
  • Use 'MatchPattern', 'FindPattern' and 'SearchPatternAndReplace' in TestStand expression.
  • Use 'Regular Expression - Case Sensitive' or 'Regular Expression - Ignore Case' in String Value Test.
-Shashidhar
(1,582 Views)
Hello Shashidhar,
from what I read here:
https://forums.ni.com/t5/NI-TestStand-Idea-Exchange/Add-Regular-Expression-comparison-type-to-String...
these functions are "recent" additions in TestStand 2020.
Thanks for the update.
Stefan
(1,574 Views)
Thanks guys,
I used a .Net Call and made Regex Test from it.
(1,564 Views)
