NI TestStand
Citrix DOORS 9.2 Client integration with Requirements Gateway - 'Error: Conversion problem (License error (feature ) NIRG_DOORS)'
What do I need in order to connect to my DOORS 9.2 database with the Requirements Gateway, while I'm using a Citrix web client? With the actual setup I get this error: 'Error: Conversion problem  (License error (feature 😞 NIRG_DOORS)'
Thank you,
Teodor
Message 1 of 8
(6,130 Views)
Maybe the following link might help
http://zone.ni.com/devzone/cda/tut/p/id/8417
regards
Ray
Note to NI: Why doesn't NI Gateway have its own board?
Regards
Ray
Regards
Ray Farmer
Message 2 of 8
(6,108 Views)
I think this information from the listed link works, but only with a DOORS client installed on the running computer. Using Citrix, DOORS will be executed from a web server (which requests an aditional user and password for accessing the Doors application itself), which means that Requirements Gateway cannot trust in the information stored into the Windows registry files or environment variables used to access the DOORS server.
So I'm waiting for other ideas.
Anyway I'll add a link here for the ones who uses local client solution for DOORS. Maybe it will be useful for them.
http://digital.ni.com/public.nsf/allkb/2CDF3F9B72AFADB5862574F700571557
Message 3 of 8
(6,102 Views)
teodor -
Would you mind if I asked the forum administrators to give me your email so that we can troubleshoot this further that way?
Manooch H.
Message 4 of 8
(6,089 Views)
Yes it is fine with me. You can ask for the e-mail if this information is forbiden to be written here.
Thank you,
Teodor
Message 5 of 8
(6,087 Views)
Teodor -
After looking into this further, unfortunately, NI Requirements Gateway 1.1 requires your system to have the DOORS client installed and does not support the web server interface.
I can submit a request to consider including this functionality in a future version of Requirements Gateway on your behalf.
Manooch H.
Message 6 of 8
(6,076 Views)
Yes this could be a good aproach in order to introduce such a feature with the next releases. If you need my support about the Citrix web client configurations you can contact me and I will try to forward you all information that you need.
Thank you,
Teodor
Message 7 of 8
(6,053 Views)
May I ask you what DOORS client is needed? What is the name of the Doors client is requred for NIRG?
+++ In God we believe, in Trance we Trust +++
[Hungary]
Message 8 of 8
(5,157 Views)
