NI TestStand
Clearing a fileglobal array of strings
I have a fileglobal 2 dimensional array of strings. How does one clear it each time the sequence is called, use a for loop? It used to not be a problem but now it seems to have old data in it all the time.
thanx,
jvh
(3,738 Views)
I don't know if there's a native TS method to empty/reset a 2D array, but much of our code (going back to TS 1.0!) simply uses the "TestStand - Set Property Value (2D String Array).vi" and a sequence context ref to reset a FileGlobals.
It has worked for us for 10+years...
(3,734 Views)
Accepted by topic author jvh75021
You can do this from an expression:
GetArrayBounds(Locals.Array, Locals.OriginalLowerBounds, Locals.OriginalUpperBounds),
SetArrayBounds(Locals.Array, "[0]", "[]"), // Make the array empty in order to clear it.
SetArrayBounds(Locals.Array, Locals.OriginalLowerBounds, Locals.OriginalUpperBounds) // Restore array back to its original size
Hope this helps,
-Doug
(3,722 Views)
Thanks.
Wished there was a one liner..
(3,695 Views)
