NI TestStand
Close reference in postUIMessage
I pass a big container as an ActiveX parameter of the PostUIMessageEx from TS to the UI, as a property object.
I typecast the ActiveXData variant to TS.PropertyObject, then I process the data. The question is, do I have to close the PropertyObject reference after processing?
(3,413 Views)
Hello Madottati,
you should close the reference, in the link below is explained why
PropertyObjects Were Not Released Warning When Using LabVIEW
best regards
Alexander
(3,379 Views)
