NI TestStand
Closing pop-up for TSComboBox
it has happened only few times when I close TastStand but since it teases my curiosity, I will be glad to discover something more.
The attached image shows the pop-up which, translating from Italian, says:
Impossible to obtain the handle of the control window ‘TSComboBox’. ActiveX controls without window not supported.
I don’t know why the same LV step which worked correctly for 50 times and more gives me this error now. Here the error message on the Repot header:
Error: Lost ActiveX connection with LabVIEW server. The LabVIEW Adapter will try to reconnect on the next execution attempt.[Error Code: -18001, An error occurred accessing the LabVIEW ActiveX automation server. ]
Thank you for the attention!
Best Regards,
Zuc
(1,089 Views)
HI  Zuc_Lab
This error occurs if the LabVIEW Development System is closed.  This could be due to a user closing the application, or an error or crash in LabVIEW.
_______
Regards 🙂
(1,044 Views)
