NI TestStand
Collect changelog of sequence while editing
Hello All,
Is there any solution to collect the changelog of the changes when editing the sequence?
I thought to have a way monitoring the changes of sequences, properties, step orders so I could build up a log array including these and save to a change history.
Thank you in advance.
CsBihacker
(2,257 Views)
There is a nice Diff tool that NI supplies with TestStand.  If you are doing proper SCC, it becomes quite simple to figure out what you changed.  The tool should be located at C:\Program Files (x86)\National Instruments\TestStand 20XX\Bin\FileDiffer.exe (fill in the year for the version you are using).
(2,251 Views)
Thanks for the superfast feedback Crossrulz.
I have something else in my mind, the TS Engine or UI engine has to store the changes, to be able to Undo back a really long list of changes somehow, I thought to get this list and use it.
I checked the FileDiffer earlier, for me this is too deep, or I need to postprocess the xml output to get what I want.
Btw what do you mean on "proper SCC"? I tried PushOK, but not satisfied 100% yet with the tool.
What are you using for SCC in TS? Is there any proper documentation about that? I did not find anything on NI site, what would be usefull.
Thx.
CsBihacker
(2,238 Views)
