NI TestStand
Coloring label
How do i color the background of a lavel (not the font themselves)
(3,889 Views)
Which label are you referring too?
Regards
Ray Farmer
Regards
Ray Farmer
(3,884 Views)
I'm sorry i was not clear.
The label i mean is from the decorate section in the control panel.
i can change the font color but could not find where i control the background of the label.
(3,879 Views)
Is this the LabVIEW Decoration?
I think the only way is to do it statically using the paint brush tool.
If its a CVI Decoration then you could use the function SetCtrlAttribute (PanelHandle, ControlID, ATTR_FRAME_COLOR, color);
where color in an int containing the RGB value for the required colour.
Regards
Ray Farmer
Regards
Ray Farmer
(3,874 Views)
Yes Ray is right!!!
To get the paintbrush tool just hold down shift and right click.  The paintbrush tool is the one on the bottom.  You can change colors by pointing to whatever you want to change colors on and then right click and selecting your desired color.
Message Edited by Sam R on 11-07-2005 10:00 AM
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,861 Views)
