NI TestStand
Combining results of previous steps into numerical test
I'm relatively new to TestStand. Here is what I am trying to do.
  1. Call VI A with numerical limits, make measurement, store value in sequence local.
  2. Call VI B without numerical limits, make measurement, store value in sequence local.
  3. Calculate: measurement A - measurement B. Compare the result to numerical limits.
Do I need to create a very simple VI with just two inputs, a subtraction function, and an output as a LabVIEW numerical limit step to implement step 3, or is there a more recommended way to do it?
Thanks.
Stephen
(4,963 Views)
Accepted by topic author stephenb2
Here's what I would do:
Call VI A as an action step.  Store the measurement in a local variable
Call VI B as an action step.  Store the measurement in a local variable
Use the None Adapter to create a Numeric Limit Step.  Set the Data Source to Locals.AValue - Locals.BValue
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,958 Views)
The None Adapter. Who knew? 🙂 Thanks.
(4,923 Views)
