NI TestStand
CommandKind_ConfigurationEntryPointDefaultMenuInsertionMarker vs CommandKind_ConfigurationEntryPointInsertionMarker
I'm trying to understand what are those "Inserion Markers" command kinds. I don't understand why ConfigurationEntryPointInsertionMarker does not inserting Result Proccesing menu item and ConfigurationEntryPointDefaultMenuInsertionMarker does. How to force to displey only Result Proccesing item and not to display Model Options? I don't understand this help part at all 😞
CommandKind_ConfigurationEntryPointDefaultMenuInsertionMarker–(Value: 113) Specifies a set of commands that contains a CommandKind_RunEntryPoint command for each Configuration entry point with a menu hint that does not select a menu other than the current menu. Because most entry points do not have menu hints, this constant typically specifies all Configuration entry points.
CommandKind_ConfigurationEntryPointInsertionMarker–(Value: 112) Specifies a set of commands that contains a CommandKind_RunEntryPoint command for each Configuration entry point with a menu hint that selects the current menu.
CommandKind_ConfigurationEntryPoints_Set–(Value: 145) Specifies a set of commands that contains a CommandKind_RunEntryPoint command for each Configuration entry point. When you specify commands to create menu items, use the CommandKind_ConfigurationEntryPointInsertionMarker and CommandKind_ConfigurationEntryPointDefaultInsertionMarker constants to honor menu hints entry points can specify.
https://www.ni.com/docs/en-US/bundle/teststand-api-reference/page/tsuiref/commandkinds.html
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(4,099 Views)
Michal,
Review the content here about CurrentMenuName and AllMenuNames. As the help topic you pointed out mentions:
I was able to do what you're looking for with the following code and process model sequence property changes:
End result:
Hope this helps,
Trent
https://www.linkedin.com/in/trentweaver
(4,080 Views)
Also, here's a useful link for anyone who comes across this post and has no background knowledge on custom commands:
White Paper: Adding a Custom Context Menu to the LabVIEW Full Featured TestStand Operator Interface
That's the code I altered in my last post.
Best,
Trent
(4,079 Views)
