NI TestStand
Communicate between TS Executions
Communicating between two threads in TestStand is easy enough using the Notification step type, but it seems like notifications cannot be used to communicate between two different executions. Is it possible to use the notification step in TS to communicate between two different TS executions? What is the best way to send messages between two TS executions?
Kevin
(3,152 Views)
Scratch that. I believe I've realized notifications do work between executions.
(3,149 Views)
