NI TestStand
Compare two changin arrays using multiple numeric test
I have an FPGA that is doing a loop test.  The FPGA will TX an array and will store the RX array to a variable.  I'd like to use TestStand to comare the TX array with the RX array.
I know I can step through the elements of an array to compare each element with a Numeric Limit Test and I know I can do it with a multiple numeric limit test but with that I have to manually put in every index and the Array will not always be the same size.
Is there a way in TestStand to say does Array = Array and then print the elements without doing the loop?
(3,932 Views)
I tried   Locals.y==Locals.x  for the if condition where both x and y are numeric arrays.
It worked fine when all the elements were matching and array size was same.
To print any variable use additional result (check help).
Hope this helps.
Ravi
(3,921 Views)
