NI TestStand
Compatibility of V2 TestStand sequences and V3 application
I have to develop sequences with a TestStand V2 application. And these sequences will run with a V3 TestStand application (deployment version).
I’m wondering if these sequences will be well executed.
Thanks for your answer.
(3,324 Views)
Kadra -
TestStand 3.0 will run the TestStand 2.0 sequences just fine. TestStand 3.0 only added new features. For a list of differences between TestStand versions, look at the release notes for TestStand 2.0.1, 3.0 and 3.1.
The only behavior that will be different is that the file will be marked as modified when opened in the 3.0 sequence editor because the newer versions of the NI types will be used.
Scott Richardson
https://testeract.com
(3,323 Views)
Thank you very much for your fast reply.
(3,317 Views)
Adding to Scot's comments.
There is a difference from TS2.0 to TS 3.0 with extra properties in the MultipleNumeric Step Type which may affect you especially if you have created Custom Step type.
Regards
Ray Farmer
Regards
Ray Farmer
(3,314 Views)
