NI TestStand
Compatibility
Hello , i am new with Teststand but i am using Labview 2011 for some time now.
My question is : Can i use Teststand v2.0 that i have to run VI's from Labview 2011 ?
If not at least which version should i use ? ( We have atm Teststand 3.1 and 4 in other departments)
Thank you in advanced for your replies
Kostas
(2,323 Views)
Please refer to this: https://www.ni.com/en/support/documentation/compatibility/18/teststand-compatibility-with-labview-an...
I don't see TestStand 2.0 on there.  Personally, I wouldn't use 2.0 as it is not even supported any more.  I would consider using 2017 for both LabVIEW and TestStand if possible.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,302 Views)
