NI TestStand
Conditional branch
Hi All!
I have a sequence:
TEST#1
TEST#2
TEST#3
TEST#4
TEST#5
MESSAGE
GOTO (TEST#8)
TEST#6
TEST#7
TEST#8
In MESSAGE in Preconditions I check if all tests(TEST#1- TEST#5) PASS.
In Post Action: ON Pass – Goto step – TEST#6.
So I expect if preconditions is True it’s skips GOTO (TEST#8) and goes to TEST#6, otherwise it skips MESSAGE and goes to GOTO (TEST#8).
Actually in any case sequence goes to GOTO (TEST#8) and skips TEST#6 and TEST#7.
How can I deal with the problem?
(2,892 Views)
I figured out how to do it:
TEST#1
TEST#2
TEST#3
TEST#4
TEST#5
GOTO (TEST#8)
TEST#6
TEST#7
TEST#8
In GOTO  in Preconditions I check if ANY OF the  tests(TEST#1- TEST#5) FAIL.
(2,888 Views)
