NI TestStand
Conditional
How do you get a popup to execute only if a certain condition is true??  ie locals.count=1
(3,406 Views)
Precondition should work just fine. If you want to get a little more complicated, use an If from the flow control steps.
(3,404 Views)
Dennis,
I tried that.  It "says" its expecting a Boolean.  I have a number ( locals.count=1)
Clint
(3,388 Views)
(Locals.count == 1) will return the boolean required for the pre-condition
Regards
Ray Farmer
Regards
Ray Farmer
(3,386 Views)
Thanks Ray.  Body is at work...mind is on vacation.
(3,384 Views)
