NI TestStand
Configuration best practice
My final deployed solution is going to consist of several PC-Fieldpoint pairs all located on the company intranet. Each PC talks to its own Fieldpoint and not any other. I have the sequences and Users.ini stored on the server.
Now I'm trying to come up with the best place to store the Fieldpoint IP address on the station. I know I could create a property loader and associated xml file, and will do that if it the preferred method. But it seems like overkill to store one IP address.
Is there a better place to store information like this? I'm a beginner, so no suggestion is too obvious for me.
I'm trying to make a system that will be maintainable by a real TestStand expert - either me in the future or my replacement<g>.
(3,224 Views)
Hi jtdavies,
It sounds like the use of Station Globals would be the ideal route for your application. Attached is an easy example showing the use of Station Globals.
Nestor
(3,204 Views)
Thank you Nestor. I just read up on Station Globals and it is just what I needed.
(3,188 Views)
