NI TestStand
Configuring Database with TestStand
  I am trying to configure databse with TestStand using the following link.But when I run the test sequence it issues attached error. I am using the sequence of the below link as well. Please help me in locating the error.
http://www.ni.com/white-paper/6484/en
(3,554 Views)
Hi capcas
I think there is a litte issue in your config of the schema. Check this firs.
Is this correct post your schema please. I will take a look on it.
regards
(3,542 Views)
  Thanks for the reply. My schema works if I remove the NAME and STATUS column from STEP_RESULT and MEAS_NUMERIC_LIMIT respectively. But the moment i add them it starts to issue error.
(3,533 Views)
Hi capcas
thanx for your update
(3,529 Views)
