NI TestStand
Configuring TS StationOptions with LabVIEW
I have an existing TestStand sequence which customizes Station Options, configures LabVIEW adapter, and configures Search Directories.
I plan to run this sequence uing LabVIEW on a Target machine with NewExecution method.
I could not get it to work. Is there something that I am missing? Comments/Suggestions are welcome. Thanks.
Attached is an image of the VI.
(4,177 Views)
I was wondering if this post should be moved to the LabVIEW forum. Thanks!
(4,144 Views)
Hi Troy12,
No this is the correct forum.  I'll try post you an example or point you at an example latter to day.
Regards
Ray
Regards
Ray Farmer
(4,139 Views)
Hi Troy,
This example may help (unfortunately I can see the contents of the VI and I dont know what version it is)
http://forums.ni.com/ni/board/message?board.id=330&message.id=14782#M14782
Regards
Ray
Regards
Ray Farmer
(4,137 Views)
Hi Troy,
I had a problem with that link I posted as there didn't appear to have a Vi at the end of it.
So I thought I had an example to post of my own, but it looks like I had a clean out of my hard drive so I'll have to do another for you, it will be in LabVIEW 8.6 hope that's ok.
Regards
Ray
Regards
Ray Farmer
(4,113 Views)
Hello Ray,
LabVIEW 8.6 would be fine. Thanks!
(4,109 Views)
Hi Troy,
Attached is a very simple example for running a Sequence in a New Execution.
I have used TestStand 3.5 and LabVIEW 8.6
Hope this helps you.
I think you problem was related to the reference for the processModelParam. If this is a NULL (Nothing) reference then use the Null Reference constant.
Regards
Ray
Regards
Ray Farmer
(4,079 Views)
