NI TestStand
Connect the executions to their ExecutionViewMgr's in parallel tests
Isn't there a more elegant solution to connect the executions to their ExecutionViewMgr's than this way (proposed by Tyler), se below ?
This way you have to send a UI message from a separate step in the sequence for each execution.
case UIMessageCodes.UIMsg_UserMessageBase: //Connect each execution to their ExecutionViewMgr
switch ((int)e.uiMsg.NumericData)
case 0:
axExecutionViewMgr1.Execution = e.uiMsg.Execution;
break;
case 1:
axExecutionViewMgr2.Execution = e.uiMsg.Execution;
break;
(3,034 Views)
FYI
Moved it to the axApplicationMgr_DisplayExecution callback function. Now I don't have to send a UI message from a separate initial step in the sequence for each execution.
int frameId;
int executionID;
SequenceContext seqContext = e.exec.GetThread(0).GetSequenceContext(0, out frameId);
executionID = seqContext.Execution.Id;
switch (executionID)
case 3:
   axExecutionViewMgr1.Execution = e.exec;
break;
case 4:
   axExecutionViewMgr2.Execution = e.exec;
break;
(3,018 Views)
