NI TestStand
Connect to Lecroy WaveRunner 104Xi over Network to TestStand
I am trying to connect to a Lecroy WaveRunner 104Xi Scope over a network (ethernet) for use with TestStand. The scope succuessfully acquires an IP and I can ping it from the host machine.
The scope responds to commands when I remotely connect to it using LeCroy's ActiveDSO software, but I cannot figure out how to use it with TestStand.
FYI: I have tried using the ActiveX/COM module in TestStand, and put in the scope IP in the Remote Host field, but have not had any luck.
Suggestions and help is appreciated.
(5,204 Views)
Alan from LeCroy Tech Support here....
Unfortunately, I am not familiar with the specific ActiveX/COM interface you are referring to in your post. If instead you are able to configure a VISA connection to the scope, then you should download and install our VICP Passport.  This is a VISA passport that handles all of the TCP/IP communications with the scope, and goes beyond NI's standard TCPIP passport.  Here's link to it: http://www.lecroy.com/tm/Library/Software/LabView/VICP.asp?menuid=8
What programming language are you using for your tests? We have both LabVIEW and LabWindows/CVI drivers for the 104Xi (the LabWindows/CVI driver is an "IVI" driver).
Best Regards,
Alan
Alan Blankman, Software Engineer
Teledyne LeCroy
800-425-2000
http://www.teledynelecroy.com
alan.blankman@teledyne.com
(5,201 Views)
Currently, I'm trying to have TestStand be able to connect to the scope to send simple SCPI commands.
I've installed VICP Passport, but I'm not sure how to use it. I don't have a copy of LabView to work with either. NI's MAX software cannot find the scope when I attempt to add the device under "Remote Device" or "Remote Visa Systems".
(5,193 Views)
MAX isn't designed to find LeCroy scopes.  Go to
Teledyne LeCroy
800-425-2000
(5,191 Views)
Oops!
MAX isn't designed to find LeCroy scopes.  But through MAX, you can launch the VISA Interactive Control (Tools - NI-VISA - VISA Interactive Control). In the "Resource to Open" entry box, enter VICP::<ip address>   (ex. VICP::172.28.19.142)  If this is accepted, then you will immediately get a new interactive control window, in which you write commands and readback responses.
Best Regards,
Alan
PS - Make sure you've installed the VICP Passport on your remote PC and *not* on the scope.
Teledyne LeCroy
800-425-2000
(5,185 Views)
Thanks for your help.
I installed VICP Passport as well as the Lecroy XStream IVI driver and now I am able to connect to the scope using the LabWindows module in TestStand. I used the resource name "VICP::<scopeIP>" and it worked.
(5,162 Views)
That's great news!  If you have any further questions, feel free to email me directly.
Best Regards,
Alan
Teledyne LeCroy
800-425-2000
(5,160 Views)
