NI TestStand
Control LabVIEW GUI via TestStand sequence
I have a VI with several buttons(controls) that the user can change during the test.
How can I associate these buttons(controls) with TestStand sequence so that during the sequence depending on a variable I set In TestStand the buttons(controls) in the VI will be activated.
Thank you,
Lev Kolomiets
(4,003 Views)
You can use variables to communicate between the two.
Scenario -1 --- Labview takes input from the test sequence :
The test sequence must update the variables.
The LV code must have a loop which looks for this variables to update the GUI.
Scenario - 2  ---  Teststand takes input from the LV front panel
For any change in the GUI update corresponding Teststand variable.
Teststand needs to loop to check for this variable.
Hope this helps.
(3,989 Views)
Lev,
Are you talking about your User Interface?  Or is it just a VI that you call from your test sequence?
If it's the User Interface then you should use UI Messages.... (Google or Bing: TestStand UI Messages.  let me know if you have more questions on that).
If it's a VI you call in a different thread from your test sequence then you will want to pass in the sequence context.  Then you can use the VIs on the TestStand palette (specifically TestStand - Get Property Value.vi).
Hope this helps some,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,985 Views)
You need to share refrences somehow. This is easy if you start your labview GUI with Teststand. I imagine you can start it with a new thread. then simply have a refrence to your control as an output. make sure you use the teststand message box options so you can see it.
You can also start Teststand with a labview GUI look at the operator interface examples. then you can simply set one of the Station Globals as a refrence to you controls
and last but not least you could have a program that starts both the GUI and the Teststand and exchanges refrences between them. There may be some other methods but thats what i typically do.
(3,957 Views)
Taylor,
You shouldn't need station globals.  Nor should you need something to start both.
There are 2 options that I consider to be better:
1- In TestStand you can have global queues.  If a queue begins with a * then it is global to the engine and anyone within the scope of that active engine can then use it.
2- The better method.  Pass your sequence context in a UI message.  Then you can use the Set and Get property VIs and pass data back and forth all day long.
Hope this helps,
jigg
CTA, CLA
testeract.com
(3,953 Views)
