NI TestStand
Conversion of ASCII char to ASCII code
Hi everybody,
is there any string function that converts a single character into its accoring ASCII code number?
By the way, Chr() works in the opposite way (ASCII code number -> string char).
Thanks in advance
Stefan
(7,416 Views)
This might work....
Under Functions:Numeric. Try the Asc() 'Obtain character value' function.
Number Asc(String string)
This function returns the character code value of the first character in a string.
Parameter 1: A string.
Returns:     The character code value of the first character in the string.
PH
(7,408 Views)
Could you please share program VI which converts the ASCII value to character.
Actually I need to show "tick mark"in one of the cell of the table.
Would you please help me out.
(7,305 Views)
Labview:
How do you get a single char in Labview? I asume you have a string right?
Pallete: Programming->String->conversion->String to Byte array  (byte = ascii code)
If the string contains only one char (the first) then you look at the first element
Teststand:
numeric->val()
edit: sorry Ted overread your reply, probably Asc() works better.
(7,301 Views)
