NI TestStand
Convert Seq file from 5.1.0.226 to 4.5.134
Can someone help me? I am in China desperately trying to setup my test lines. My engineer that was working on all of this quit and I am trying to pick up where he left off. Our TS deployment was done in TS version 4.5.1.134, but the sequences were last saved in version 5.1.0.226.
Would someone be able to save my sequences (attached) in version 4.5.1.134 or earlier?
(5,099 Views)
Thanks so much!!!  It worked.  I owe you a beer or two....
(5,083 Views)
You're welcome.
Do you know Maredsous? I'm not a big fan of Tsingtao... ^^
(5,076 Views)
For future reference, you can do "save as previous" in the TestStand Sequence Editor. When you do "Save As", select the corresponding version of TestStand from the "Files of Type" combo box. Then when you save, it will convert the file for loading in that version of TestStand (to the extent to which it's possible).
Hope this helps,
-Doug
(5,066 Views)
