NI TestStand
Convert number to reversed byte array?
How do I convert a value, say 10000, to a 4 byte array then reverse the byte order? Is there a function for this or ??? I can easily do it in LabVIEW but I am wondering if it's possible in TestStand.  Thanks!
(5,383 Views)
Accepted by topic author PatSpring
in TS you clould do this with looping on an expression
Parameters.arByte[RunState.LoopIndex]=(Parameters.nValue >>(0x8* RunState.LoopIndex ))&0xFF
Just take a look at the attached example.
Regards
juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(5,360 Views)
Thank you very much! Works exactly as I needed!
(5,355 Views)
