NI TestStand
Converting ATML report to PDF
Is there a way to convert ATML report to PDF.
Alternatively log directly to PDF ?
(2,810 Views)
By this link you can check the discussion similar to your question. The point is that you can use some free pdf printer, and afterwords programatically convert to pdf-file.
But, unfortunatelly, there is no such built-in functionallity.
Finally, you can create your own report processor, which will create directly test reports in pdf format. Could be quite usefull, by the way...
Sincerely, kosist90
(2,776 Views)
