NI TestStand
Converting CVI Actions to C++/dll actions in TestStand 4.2.1
I have a sequence which contains both CVI Actions and C++/.dll Actions throughout the sequence.  I wish to convert all the CVI actions to C++/.dll actions without having to create a new step and copy/paste all parameters, step names, expressions, etc.  It would be a tremendous task to do so.  Is what I am seeking even possible?  Basically it would be ideal if I could just change the CVI action to a C++/.dll Action in a given step while keeping all the module parameters the same.
Thanks in advance,
J Korn
(3,065 Views)
Accepted by topic author J.Korn
Select the step
Go to the Properties tab
Click on General
Change Adapter: to C/C++ DLL
You can select multiple steps and do this once for all of them.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,064 Views)
Thanks a bunch!  I should have known better......
(3,060 Views)
