NI TestStand
Converting a string to an int (returning null, not zero)
I need to convert a string to an int, however, if the value does not convert directly to an int, I would like it to return null, rather than 0 (which Val() returns).
(3,270 Views)
Accepted by topic author BIOSphere
You can use the following expression to convert a String into an Int:
Locals.Number = Str(Val(Locals.String),"%d") == Trim(Locals.String) ? Val(Locals.String) : NAN
If Locals.String contains an integer then it will assign the value to Locals.Number, otherwise it will assign NAN.
I hope this helps,
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
(3,255 Views)
Thank you!
What if I need that number to be in decimal format (ie. 3.270)?
I noticed that when I type a decimal in, it will not format it correctly into an int.
(3,234 Views)
If you need it to work for decimal numbers, rather than integers (whole numbers), use the following expression:
Locals.Number = Str(Val(Locals.String),"%g") == Trim(Locals.String) ? Val(Locals.String) : NAN
Kind regards,
(3,223 Views)
