NI TestStand
Converting decimal variables to octal labels using TestStand expression?
Hello all,
I am currently using TestStand to read and write ARINC data for my application. Now, the ARINC card only takes decimal values, so I must convert all the octal labels to decimal and set them in TestStand such that the ARINC card accepts it. So, when I read the variables coming out, I name them for the log file, but I need to convert the decimal values to octal labels such that the test operators do not get confused.
All in all, I need to know is there an expression to take the decimal value and convert it to octal in the expression space?
Thanks!
CLD | CTD
(4,870 Views)
Not aware of any expression for conversion.
But i tried this.
Declared two variable:
One normal number type ( which holds decimal value).
Other a  number type but numeric format changed to octal.
Whenever i need to display octal from decimal then use this in a statement step type ---- locals.oct = locals.dec
When need to convert dec to oct then locals.dec=locals.oct.
For showing to user in message popup str(locals.oct) will work out will display in octal and str(locals.dec) will display in decimal.
Hope this helps.
(4,859 Views)
Accepted by topic author ChrisK88
Convert to octal string: Str(Locals.Local, "%#o")
Remove the # if you don't want the radix prefix.
Convert to decimal string if you want an integer:
Str(Locals.Local, "%i")
or for floating point:
Str(Locals.Local, "%g")
Hope this helps,
-Doug
(4,846 Views)
Hope this helps,
-Doug
I think this does not work for Octal numbers, right ? I can't turn off the radix prefix for octal numbers.
(3,254 Views)
