NI TestStand
Copy result container - why do I get a property types do not match error?
I am creating a Teststand sequence that parses through the ResultsList and creates my own format of text reporting file. (I need to do this because our database needs the data in a very specific text format).  I am trying to copy a Result from a subsequence back up into the first level of the ResultList. (see attached screen shot for the details).  I use the following statement:
Locals.TestResultListLocalCopy[3] = Locals.TestResultListLocalCopy[1].TS.SequenceCall.ResultList[0]
When I execute the sequence I get the following error for the above line:
-17321; Variable or property types do not match or are not compatible.
As you can see from the screen shot that I took at run-time, both of the array elements are of type Result, so why do I get the type error?
Thanks for any help - LAW
(4,105 Views)
FYI - Attached is a very simple sequence file that generates the same error
LAW
(4,081 Views)
Hi LAW
I have rewritten your programm. I used the Methods Clone and SetPropertyObject from PropertyObject Class.
Test it.
I hope it was you are looking for
Greetings
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(4,064 Views)
That works! Thanks!
LAW
(4,037 Views)
