NI TestStand
Could not find Function DisplayTimerMsgImgPopup in DLL
I just upgraded to TS 4.2.1 from 3.1.  I created a new sequence, in which, I put a message popup.  When I try to run that step, I get the following error: Could not find Function DisplayTimerMsgImgPopup in DLL (or external module) C:\Documents and Settings\All Users\Documents\National Instruments\TestStand 4.2.1\Components\NI\StepTypes\MsgBox\msgbox.dll.  I used Dependency Walker to examine the DLL in that location and that function does not exist.  It seems that since the message popup is a selectable Insert Step type, that function should be part of the base setup distributed in the installation.  Why does the Message Popup try to use that function if it is not included in the DLL?  Any help would be appreciated.
Tracey
(3,380 Views)
It's there in my 4.2 installation. Perhaps you copied your 3.1 steps to the 4.2 folder? What's the size of the dll and date?
(3,376 Views)
Yep, that was it.  I grabbed the wrong one.  Thanks for your help!
(3,372 Views)
