NI TestStand
'Could not load frontend.dll'
Hi all. I am new to the TS 2019. When I tried to log in the MMI, the following error message turned out.
---------------------------------------- Details: Could not load DLL or external library 'C:\Program Files\National Instruments\TestStand 2019\Components\Callbacks\FrontEnd\x64\frontend.dll'. Cannot load SxS version of cvirte.dll required by the DLL. Verify you have the SxS CVI run-time engine installed. Function LoadLibrary failed. Win32 Error Code = '1114' Error Message = 动态链接库(DLL)初始化例程失败。 ---------------------------------------- Error Code: -17004; Could not load DLL or library. ---------------------------------------- Location: Step 'Login' of sequence 'LoginLogout' in 'FrontEndCallbacks.Seq' ----------------------------------------
I have found the cvirte.dll and sxs.dll in system32 and sysWOW64, so this maybe caused by other errors.
Thanks for your help!
Best Regards
(2,530 Views)
I would recommend running the version selector for TestStand.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019PfGSAU&l=en-US
Even if 2019 is the only version you have installed it would help to make sure all of the activex components and adapters are set correctly.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,475 Views)
