NI TestStand
Could not open .pdb file
Environments:  Test Stand 4.2.1, Labwindows/CVI 2009
Menu:  Configure ->Adapters->Labwindows/CVI
Issue:  When I change the execution from "In-Process" to "External Instance"  and then try to step into the CVI debug build , I get the following error:
No .pdb file is built when I invoked the  Build-Create Debuggable Dynamic Link Library from LabWindows command.
Debugging when the adapter is set to "In Process" works fine.
(4,367 Views)
Did you get a chance to look over this Knoledgebase article? It talks about a step by step way to debug a CVo application from Testand. If you follow this, do you still get an error?
Here is the link:
http://digital.ni.com/public.nsf/allkb/0C0EBF781B7702E886257620005368B5?OpenDocument
Please let me know if it helps.
Sal H.
(4,332 Views)
