NI TestStand
Could we pass through the ActiveX Adapter a c structure ?
Today, in my ActiveX methods, I pass 3 arguments in order to process errors in TestStand. Here are :
             short *errorOccured
             long *errorCode
             char **errorMsg
In TestStand, I am using the 3 following variables :
             Step>Result>Error>Code
             Step>Result>Error>Msg
             Step>Result>Error>Occured
For each method, I have to pass this 3 arguments. It's quite long and boring so is it possible to pass a c structure ?
To avoid this 3 arguments, I would like to pass a c structure with this 3 arguments and so in TestStand I would like to pass the following c structure :
             Step>Result>Error
(4,182 Views)
Hello Lilie,
You can find, in the links below, a response to you question:
http://digital.ni.com/public.nsf/websearch/129785F0AFABB90A8625686E005AE407?OpenDocument
http://digital.ni.com/public.nsf/websearch/AC5008A6FC55616F86256BBC005B61D8?OpenDocument
Hope this help
Regards
Sanaa T
Sanaa T.
National Instruments France
(4,171 Views)
I did not find a direct answer to the question in those links.
The answer is:
The ActiveX adapter supports Automation compatible types.  This does not include language specific types such as C structures (although the DLL adapter does support C structures).
For ActiveX, you can pass Step.Result.Error as a single PropertyObject parameter, and then use PropertyObject api to access the sub-fields in your code module.  If you need help doing this, please specify the ADE you use for creating your server (ie. LabWindows/CVI, VisualStudio/C++, ..).
(4,161 Views)
Thanks James,
I am using LabWindows/CVI 6.0 with TestStand 2.0 for the moment.
Your answer interests me much.
See you
Lilie
(4,131 Views)
In your CVI code, you will need to convert the error parameter to a CAObjHandle.  The following code sets the appropriate values.
TS_PropertySetValNumber (errorObj, NULL, "Code", 0, -15);
TS_PropertySetValString (errorObj, NULL, "Msg", 0, "A very bad error");
TS_PropertySetValBoolean (errorObj, NULL, "Occurred", 0, VTRUE);
Allen P.
NI
(4,116 Views)
In the following link: http://digital.ni.com/public.nsf/websearch/AC5008A6FC55616F86256BBC005B61D8?opendocument&Submitted&&...
There seems to be a small error in the text on line: -  "Calling Sequence:  RunState.Caller.RunState.SequenceFile"
I think this should be : -  "Calling Sequence:  RunState.Caller.RunState.Sequence"
Regards
Ray Farmer
Regards
Ray Farmer
(4,106 Views)
Hi everybody,
I know there is a long time, I asked my question. When I do this, it was by curiosity, but today I really need this.
So I tried what James had advised.
But it seems to do not work. I probably forget something. In order to understand me rapidly, I sent my CVI application sample (a ActiveX server application) and a sequence file (TestStand 2) which call my activeX server.
Lilie
PS : I think, I do not use the right type for my errorObj...
(3,986 Views)
