NI TestStand
Create TS enum from labview
I need to create costom type definitions in TeststandSeqnence file, I will have more than 400 enums to create.
Is there a way to create enum and define its values from labview using testtand API?
(3,331 Views)
You mean want to create typedef automatically?
Programmatically Create a Type Definition Using VI Scripting
Certified LabVIEW Developer
GCentral
(3,298 Views)
No, I need to stript enum typedefinitions placed inside teststand sequence file:
If posible I would like to use TS API and labview if possible.
(3,276 Views)
Go in the module tab where you call your VI.In the list of parameters of your VI, identify your enum. You should see an icon to create/Update data type of the enum in TestStand
Regards
(3,239 Views)
It is an option but if I have more 350 enums I would have to create 350vis and pass them to sequence and click on create or update icon.
(3,228 Views)
