NI TestStand
Create Type NI_MultipleNumericLimitTest for local variable
I am using  Multiple numeric test in my seq &  documenting in case of   Seq fail
i.e when the  value is not in the limits
I am using for-each-loop step type for this
I want  a Local variable  of type  NI_MultipleNumericLimitTest      in my foreach (current element )
but am not able to generate   a local of tht type!!
what   measures to take to do so
(4,595 Views)
You cannot create a variable of a step type.  Step types can only be used to create steps.
What is your goal?  Maybe there is a better way to accomplish what you want.
If you are looking to dynamically change the limit set you need to use other types like NI_LimitMeasurmeent or an array of those.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,587 Views)
hi,
its fine now
I just used a container  for the   Current_Element  .
I kinda jumbled up ,  hence thought  as the array is of type MeasurementTest
I shld  be using the  same type for  the variable   which is going to hold the element
regards,
akshay
(4,572 Views)
