NI TestStand
Create and log arrays of data
I have a sequence which has a LabVIEW action step inside of a for loop.  This step outputs a single voltage measurement.  This for loop has many other steps in it as well.  Right now, if I tell my measurement step to log its data, I will see the one result for each pass in the for loop separately.  I would like to log all of the data from this measurement step in an array (where each element of the array corresponds to a pass through the for loop) so that the operator can see the results as a plot (or at least an array) instead of as single values scattered throughout the report.  Does anybody know how I would go about doing this?
Thanks!
(3,453 Views)
In the Post Expression of your Step use an expression similar to
Locals.readings.SetValNumberByOffset(Locals.index,1, Step.Result.Numeric).
This will record your measurement and store it in an array using your loop counter. Using this expression means you dont have to initialise the array to a fix dimension as the value of 1 for the Options means 'Insert if element is missing'. (Check out the Programmer Reference Help for SetValNumberBy Offset).
alternately you can use
Locals.reading[Locals.index] = Step.Result.Numeric. (but for this expression you will have to set the dimension of the array, ie it can not be empty)
hope this helps
Regards
Ray Farmer
(3,445 Views)
Ray,
Thanks, that helps get the data into an array - do you know how to then write the array to the log/results file?
Thanks!
(3,433 Views)
If you are using a recent version of TestStand you can use the Additional Results step type, or Additional Results setting on any step.
Hope this helps,
-Doug
(3,431 Views)
As dug suggests and if you want to display as a graph, then use the Include Arrays - Insert Graph in the ReportOptions, but you have to be using HTML or XML
Regards
Ray Farmer
(3,427 Views)
Thanks Doug and Ray - I have things working now! 🙂
(3,407 Views)
