NI TestStand
CreateDeleteUsers
I've seen the example sequence file CreateDeleteUsers.seq. and I stepped through the example and got it to work.  However, I want, instead, to have this functionality available to the user from my (customized test exec) from the Configure Menu.  I added a Configuration Sequence to my process model, and after configuring it, I see it in the drop down list. In the Main of that sequence, I added a message popup just to see that it would call it at runtime, and it did.  I later replaced that with an Action call to simple VI.
What I want to do now, is create a VI that looks similar to the attached png (from an excel example), yet lets me add/delete users.  I'd llke this to be available only to Admin types.   I would initially populate it with the current list of users, then add to it if the user adds a name in the blank line above this list.  What LabVIEW widget lets me add names to a list (of strings) like shown?
Also, in my very minimal experimentation, I had made the call to the VI from a sample sequence file - it runs, returns, and says "Passed".  I don't want it to generate a test result.  Any suggestions?
Message 1 of 15
(5,766 Views)
I have the code snippet (attached) that gets the Engine->UserFile->UserList, but I don't know how to get the list out to an array of strings, so I can populate my list menu, and start this thing off.
Message 2 of 15
(5,756 Views)
Hello Mrbean,
the UserList is a PropertyObject, which contains all User objects. You can not directly get the LoginName string from UserList object, but from the User object.
I have attached an example, may that can help you.
Regards
MY
Message 3 of 15
(5,747 Views)
Hello Mrbean,
sorry, i think i don't have completely misunderstood your last question.
Again, the UserList is a Property Object that contains an array of all User Objects. You should save all information from every User Object (Like FullName, LoginName...) into a cluster, then build an array of those cluster.
Regards
MY
Message 4 of 15
(5,744 Views)
How did you create the "User" constant going into the 'type' input of the Variant to Data (inside the for-loop).  If I go to the UserFile or UserList outputs and right-click, I can create a constant of their respective types, but I don't see User in the Select ActiveX Class list?
Message 5 of 15
(5,732 Views)
I've changed gears, and I'm doing all of this from my process model instead, taking advantage of ActiveX calls.  I've got quite a bit of this working, but I can't figure out from ActiveX, how to display (I do this only for an Admin) all the available users so he can select the one that he wants to edit.  I have the UsersFile and I've got the UserList, but I'm not sure how to get the LoginName (if that's what I need) of each to display in a popup for the admin to choose from.  I want to pass the selected user to the DisplayEditUserDialog.  Thoughts?
Message 6 of 15
(5,729 Views)
Hi Mrbean,
please see the attachment, it is a Sequence file which collects all LoginNames in an Array.
And in my LabView Program i have create an User constant from Engine.GetUser function.
Regards
MY
Message 7 of 15
(5,722 Views)
Any idea what the sytax error is in you statement?  TestStand is complaining
Locals.LoginName[Locals.UserIndex] = Locals.UserListRef.GetPropertyObjectByOffset(Locals.UserIndex, 0).AsUser.LoginName
Message 8 of 15
(5,701 Views)
Hello Mrbean,
do you mean this? It is "No Errors" now.
Locals.LoginName[Locals.UserIndex] =  Locals.UserListRef.AsPropertyObject.GetPropertyObjectByOffset(Locals.UserIndex, 0).AsUser.LoginName
Regards
MY
Message 9 of 15
(5,684 Views)
Now that I have the list of user logins (array of strings), I'd like to use an ActiveX call to TestStand or LabVIEW or Windows,to display a popup containing the users (by their logins), and it needs to allow the operator to select one of those names.  This name would then get passed to the DisplayEditUserDialog.  Thoughts?
Message 10 of 15
(5,658 Views)
