NI TestStand
Creating a thread
Hi everyone
I have a sequence where I have to send a message every 5 seconds or my part will go to sleep. Well while I need to do that I also need to send other messages to the part. So I was thinking of creating a thread that will run in the background sending the required message every 5 seconds and then the main sequence will just run normal. I have never done this in TestStand so I'm asking for any kind of help on creating threads.
(3,426 Views)
Oh yeah I'm using TestStand 4.0
(3,424 Views)
Hi, yaz,
You may create a multithreaded sequence call. All you need to do is to select "use new thread" under execution option in the step settings for the sequence call.
Song
Song Du
Systems Software
National Instruments R&D
(3,402 Views)
