NI TestStand
Creating data folders from UUT
I`m sure this has been asked in previous topics but i just can not find the answer to my problem.
I would like to create a folder which has the name of the UUT as the folder in which i will store raw data from my tests. I have created a statement called Locals.data_folder and give it the variable "C:\\data\results" but how do i go about creating folders based on the UUT from TestStand?
Any help is most welcome.
James
(5,150 Views)
James,
i recommend that you write a module (C/C++, .NET or LV) to create and name the folder. Pass the UUT ID (serial number) as parameter to that module.
Norbert
Expert: Geometry
(5,148 Views)
Thanks for the reply. I did try using a call executable with "/C echo test>>mkdir D:\\TestStand\TR123" as the argument expression but this didn`t work.
I`ll try using a piece of LV to generate the folder.
(5,106 Views)
Accepted by topic author Treble20
Hi
no need to use LabVIEW to do it.
You can use in TestStand the call executable.
In the step settings, go to call settings.
File Pathname: cmd (C:\windows\system32\cmd.exe should be write behind the file pathname).
In argument expression: "cmd /c mkdir D:\\TestStand\\TR123\\" + Locals.String.
You just have to set Locals.String with the name you need.
Regards
(5,102 Views)
Works a treat. Thanks. Taking the echo out means the code now works.
(5,099 Views)
Potentially another thing why your code didn't work:
You had a \T in the path which escapes to a tabulator. To unescape, the second \ is necessary (=> '\\').
Norbert
Expert: Geometry
(5,092 Views)
