NI TestStand
Creating or Deleting Users with simple OI
For my simple OI, I wanted to add a method of creating or deleting users. I didn't like the way of calling the seq createdeleteusers.seq.
Instead I wanted to intiate through a activation of a button from simple OI.
So I created a sub VI called user manager which allows only administartor (prechecked in simple OI) to create or delete users. Reference of teststand engine need to be passed to sub vi from simple OI.
attached is the sub VI for creating or deleting users, Is this the right way of doing it?
I am using LV 8.2 and teststand 4.0.
Regards
Prav
(3,625 Views)
Hi Prav,
I have found this community example which I am confident does exactly what you want to do. I suggest you download and take a look at this code.
I hope this helps.
Best Regards,
Christian Hartshorne
(3,595 Views)
Accepted by topic author prav
Thanks Christian,
I had look at the code and it is lamost similar or even better as my single GUI does both add and delete operation but surely  I can grab some nuggets.
Regards
Prav
(3,592 Views)
Rather than actually modified UI code, you could simple add an item to the Tools Menu.
see the following Link
Regards
Ray Farmer
Regards
Ray Farmer
(3,576 Views)
