NI TestStand
Creating the Simplest OI of all time....
Hi All,
I am new to LabVIEW and TestStand, and started using it about 2 weeks ago.
I have since then created some VIs and used them to talk to external hardware. I then ran these VIs in a sequence in TestStand.
I am trying to create a very simple OI: Choose a sequence, run it. That's literally it, and I've found that trying to modify the simple OI example is basically impossible for me.
Any suggestions about where to start?
Thanks!
(2,192 Views)
You could just write a simple VI in LV that will just call the existing TestStand UI through the command line.  Refer to this: https://forums.ni.com/t5/Example-Programs/Passing-Custom-Command-Line-Arguments-to-a-TestStand-Opera...
This would be super simple and require minimal work on your part.
Otherwise, if you want a legit UI then you would need to dive into and understand the different parts of the existing UI and strip it down to what you need.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,042 Views)
