NI TestStand
Creating value expressions dynamically with strings and numbers?
Hello everybody!
I'm having a problem regarding passing arguments (DLL-Adapter) from different locations to a function in TestStand 3.5.
Here is what I have:
FileGlobals.Data.MyArray
and
StationGlobals.Data.MyArray
Which means there are 2 arrays of the same type, one stored in the sequence and one globally. "Data" is just a container.
The type of MyArray is a custom one each element containing a string and a number: Array[n].Name and Array[n].Nr
Now I want to pass (string) arguments of the array to a function using a value expression of: FileGlobals.Data.MyArray[Step.index].Name
Whereas Step.index is a local property (number) of a custom step. It's working well!
Here is the actual problem:
Since I have to sources, FileGlobals OR StationGlobals, I want to specify dynamically which string to pass.
Therefore I introduced a property Step.ThisIsMyScope . It's a string containing either "FileGlobals" or "StationGlobals".
I have been experimenting in expressions like
Step.ThisIsMyScope + ".Data.MyArray[" + Step.index + "].Name"
or Evaluate(...) , etc.
Nothing worked.
I do not want to use the API, though I managed to do things with getValString and temporary saving the Value in the step, but that's not nice nor transparent enough.
May anyone help me?
Thank you very much,
Stefan
Message 1 of 16
(4,616 Views)
have you tried Evaluate(Step.ThisIsMyScope + ".Data.MyArray[" + Step.index + "].Name")
or
(Step.ThisIsMyScope == "FileGlobals"  )  ?  (FileGlobals.Data.MyArray[ Step.index].Name)  :  (StationsGlobals.Data.MyArray[ Step.index].Name)
Regards
Ray Farmer
Message Edited by Ray Farmer on 04-05-2007 10:09 AM
Regards
Ray Farmer
Message 2 of 16
(4,614 Views)
The first one does not work. ("token" error)
The second option is surprisingly good, I even can do something like a switch statement (ok, it's not that good to read, but it works).
So the second work-around is working in my case, although it is not completely dynamic. What if I had wanted to actually "use" the string to build up my expression? Maybe the conditional statement may help me there too, but right now I can't see how?
Message 3 of 16
(4,615 Views)
I think you have to do:
Evaluate(Step.ThisIsMyScope + \".Data.MyArray[\" + Step.index + \"].Name\")
so you dont get the token error
Regards
Ray Farmer
Regards
Ray Farmer
Message 4 of 16
(4,613 Views)
No, that's not working: it says "unexpected token : \"   !
Message 5 of 16
(4,612 Views)
Ok
Evaluate(Step.ThisIsMyScope + ".Data.MyArray[" + Str(Step.index) + "].Name")
The parameter of Evaluate must be a string, and I'm guessing Step.index is a number so convert it to a string.
Regards
Ray Farmer
Regards
Ray Farmer
Message 6 of 16
(4,612 Views)
Actually that's what I tried first, because it seems quite obvious to me. Unfortunately this leads to : "unexpected token : . "
TestStand does not like the first dot at --->  ".Data.MyArray[" !
If I remove it, the error is gone but then the property is not correct... Smiley Indifferent
Message 7 of 16
(4,611 Views)
Should that be Data.MyData or Is it DataMyData?  What is the full structure of Data?
I've just tried a similar example which worked for me using TestStand 2.0
Can You post a small example.
Regards
Ray Farmer
Regards
Ray Farmer
Message 8 of 16
(4,609 Views)
Here are two examples that show the full structure of the data assuming that we want to get the 3rd element of each array:
FileGlobals.Data.MyArray[3].Name
respectively
StationGlobals.Data.MyArray[3].Name
to clarify it even more:
StationGlobals (Default Top Level)
         |----Data                (container)
                  |-------MyArray        (array of custom type)
The custom type contains:
|----- Name (string)
|----- Nr (number)
I hope it is clear now. How is your structure and the corresponding expression?
Message 9 of 16
(4,604 Views)
I'm not seeing the problem you are having.
if you put FileGlobals.Data.MyArray[2].Name in the expression
Locals.expr = Evaluate("FileGlobals.Data.MyArray[2].Name") do you get the expected value returned in Locals.expr.
Regards
Ray Farmer
Regards
Ray Farmer
Message 10 of 16
(4,574 Views)
