NI TestStand
Creating value expressions dynamically with strings and numbers?
Of course I do!
THIS is working even if I'm not accessing the 2nd element with a constant but with a variable! ( FileGlobals.Data.MyArray[Step.Index].Name )
The problem I'm talking about is:
 I can not replace "FileGlobals" with a variable, runtime-given string.
Message 11 of 16
(1,496 Views)
Can you post an example sequencefile highlighting your problem.
Regards
Ray Farmer
Regards
Ray Farmer
Message 12 of 16
(1,493 Views)
Ok, here we go:
There are 3 Steps (see expressions).
The aim is to get a value from an array which may exist at two different locations.
Explanation:
The first step is OK as I'm specifying the value expression "path" directly.
The second one is trying to build an expression at runtime using its local "Step.Scope" string ! Same for the third one. They fail because of a syntax error (I' ve tried many ways there, all of them giving a syntax error, so this one only shows the principle of what I want to do).
Please try to rewrite the post expression using "Evaluate(...)", "Step.Index" and "Step.Scope" (without using the conditional operator "?:" ) to create an expression that can get the desired element of the array.
Message 13 of 16
(1,486 Views)
Quick look at your sequencefile:
On the second step you are not changing Step.Index to a string and the second item, dont you need to include Name in the string as Step.MyResult is of type string not Type Info.
[SF.Seq[0].Main[1].TS]
Id = "ID#:UfdOFg1uu0+wU3MUymaGrC"
PostExpr = "Step.MyResult = Evaluate( Step.Scope + \".Data.Array[\" + Step.Index + \"]\")"
It needs to be of the format
PostExpr = "Step.MyResult = Evaluate( Step.Scope + \".Data.Array[\" + Str(Step.Index) + \"].Name\")"
Regards
Ray Farmer
Regards
Ray Farmer
Message 14 of 16
(1,475 Views)
I accidentally forgot the ".Name" in my quick example, you're right.
I have changed my expression to the one you provided. First I got an token error because of the dot ("."). Then I ran the sequence, it worked!
I made the following mistakes that led to my problem:
- providing the Evaluate expression with ' \ ' included, like: Step.Scope + \".Data.Array[\" + Str(Step.Index) + \"].Name\")". Now I'm realizing that this is only the way TS is storing the value! So in the expression box you can write:  Evaluate ( Step.Scope + ".Data.Array[" + Str(Step.Index) + "].Name" )
- confusing the token error "." with a syntax error: The syntax of " Evaluate ( Step.Scope + ".Data.Array[" + Str(Step.Index) + "].Name" )  " was correct, but the property only exists at runtime!
- using Step.Index instead of Str(Step.Index) !!
A very weird mixture of these mistakes have led to the problems I had. Thank you Ray for helping me out so patiently! I'm glad about your help!
Thank you!
Message 15 of 16
(1,470 Views)
That's ok, still got a bit of hair leftSmiley Very Happy
Regards
Ray Farmer
Regards
Ray Farmer
Message 16 of 16
(1,461 Views)
