NI TestStand
Custom CVI interface Without NI Teststand UI Controls
Hi
Does anyone have an example of a Teststand Operator Interface which does not use the NI Teststand UI Controls library?
What im trying to do is create a list of all sequences in a folder and populate a List box.
The user would then double click the Test to load it.
And a click on a button would then run the UUT Test for the loaded sequence.
Help share your knowlegde
(3,018 Views)
You should still use the Application manager control at least, because it takes care of some of the details for you like, login/logout, loading type palettes, shutting down, etc. You could start with the simple UI example.
Hope this helps,
-Doug
(3,005 Views)
