NI TestStand
Custom Looping Multiple Numeric Limit Test SequenceFilePostStepFailure
Hi
I am using a custom loop on Multiple Numeric Limit Test. The SequenceFilePostStepFailure callback is called each time the loop fails and called again when the step fails.
I want to do something (not relevant for this question) when it is looping and something else when the step fails. How do I know the difference? Is there any flag to look for?
I have tried looking at several variables under RunState but haven’t found the right one. Is there one?
Thanks in Advance
Kim
(3,347 Views)
Kim,
Try Runstate.Caller.Step.Looptype you can compare this to NoLooping.  If NoLooping then the step doesn't loop.  You can also use Runstate.Caller.Step to get a Step object and then just use the API calls to manipulate it.  You can read about it in the TS help.  To get the loopindex try: Runstate.Caller.Loopindex.
Both should be ran in the SequenceFilePostStepFailure Callback.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,319 Views)
In the SequenceFilePostStepFailureCallback you could check:
Parameters.Step.AsStep.CurrentLoopResult == Nothing   // requires loop results to not be disabled or it will always be Nothing
or
Runstate.Caller.RunState.LoopIndex == numberOfLoopIterations
(3,316 Views)
