NI TestStand
Custom Report generation in the Simple UserInterface
I've created a workspace, a project and some sequences in TestStand 4.0. I've also created a custom report generation. This all works fine in TestStand.
The custom report file is a txt file. The custom report generation is chosen above the default report generation, because the workspace directory is placed at the top of the "Search Directories".
When I open the main sequence file of this project in the SImple UserInterface, the the default report generation is used. Why doesn't it use my custom report generation? And how can I solve this problem?
Niek Laverman
3T bv
Message Edited by Niek L. on 06-23-2008 07:00 AM
(3,078 Views)
Niek L.
Before we address your current problem, let me describe a bit about what is currently happening.  First, when working with TestStand, the .tws file that is created when you save a workspace file is something that can only be opened in the Sequence Editor environment.  Which explains why, when you try to open this file using the Simple UI you get an error.  Since you can't open a workspace file in a Simple UI the search directory that your workspace uses is not valid.
The easiest way to address this situation is to create a custom search directory from TestStand»Sequence Editor»Configure»Search Directories... then select Add.  This will allow us to hard code a path that will reference the appropriate directory that the workspace is located in.  We can then move this custom search directory to the top of the list.  Now, when we use the use the Simple UI we will be able to load that sequence file because it is now part of the available search directories.  This should also allow you to be able to load your custom report generation.
A_Ryan
AES
(2,993 Views)
