NI TestStand
Custom Step Type Window error
When I try to edit a Custom Step Type I cannot see any of the options in the window because the window size is too small for the pop-up. See Image.
How can i fix this so i can edit my Custom Step Types?
Using TestStand 2016 (16.0.0.185) 32-bit
(3,963 Views)
Have you tried expanding the window from the bottom right corner of the window?
-Mitchell | NI
(3,903 Views)
Why didn't I think of that???
/sarcasm
(3,894 Views)
What OS and version are you using?
Have you ever seen this before?
(3,872 Views)
Windows 7.
Never had issue until TS 2016.
(3,850 Views)
Can you reproduce the behavior?
If you create an identical step, does the window do the same thing?
Can you attach your sequence files so that I can try on my computer?
(3,786 Views)
